While zymoling my 6 month old Boxster S after less than a week' s ownership (I' m the 2nd owner), I discovered some strange marks under the paintwork on the bonnet just below the badge. The marks look like water marks in a £5 note and cannot be removed by normal polishing.
The local OPC where I bought the car from have agreed to try to rectify the problem but what worries me is that they say they will use some form of heat treatment to remove the marks. Failing this, the whole bonnet will need to be resprayed ( which I want to avoid if at all possible).
Have any other owners had similar problems and if so were they satisafctorily rectified? The OPC staff suggested that similar marks had been found on Lapis Blue cars but I' m not sure whether it is only dark coloured cars that are affected (mine is Basalt Black).
I have also discovered that some of the paint on the very bottom of the nearside rear wheelarch has started to peel off. Again the OPC has agreed to sort it under warranty, but the paintwork problems have somewhat taken the edge off the pleasure of owning what is almost a new car. If these are examples of Porsche' s legendary build quality, I' ll have myAudi S3 (which was better built and equipped) back, together with the extra £23k I had to stump up for the Boxster!
Any other owners had problems with peeling paint?
