Panamera PCM rebooting
- Thread starter Thumpick
Have you tried the reset procedure for your rebooting issue. Worth a try:
BEWARE as you will WIPE ALL STORED DATA since this is a factory reset. The video refers….
I have seen some forums that describe cloning the HDD. I would however be cautious unless you felt comfortable with having a go as its not a straightforward procedure.
Failing that, I think the next course of action would be a repair. It’s probably a loose or dry connection on the motherboard, connector or component failure. Could also be the HDD. There is a Boxster thread on the PCGB forum which gives some more info and possible repairers - not cheap (but cheaper than a new PCM)
981 PCM3.1 Hard Drive Failure? Repairs anybody? | Porsche Forum from Porsche Club GB
The author refers to a repairer that he has used and it would be worth considering removing your PCM unit and sending it down to them:
In-House PCM repairs for Porsche Radio | Amp | Navigation Systems - PCM Repairs
Or what appears to be the same organisation:
Cartronics – Car Electrical Specialists
The removal of the PCB can be done by yourself (you will need the removal tools that you can get on ebay - he made a set himself) or your local independent. The procedure seems straightforward enough:
Panamera radio and PCM removal and installation - PanameraClub.com (insanegarage.com)
If you send the radio off they will diagnose the problem and send you a repair and time to fix estimate. Expect something like £1250 incl. VAT and 3 weeks. Its worked perfectly since after motherboard replacement. You will pay about double that for a new replacement unit unless you manage for find one from a salvage car.
Trust this helps.
Kind regards,
Randall
SpyderDavid
Cost was about £150 including a disk cloner and a top spec SSD. If you feel up to removing the HDD (4 torx bolts, 2 screws and 1 connector) even if it’s failing your local PC expert may well be able to recover the contents and clone you a new one. I’d be trying this before I spent £1250….
Bonus of the SSD is it’s appreciably quicker.
I tried the manual reset using the YouTube links but no joy. I ended up sending off to Cartronics. They wouldn’t give me an estimate over the phone so I got a shock when they said it would be £1300 to repair. I said no thanks so had to pay £90 for diagnostic and postage.
Ended up finding a repair service on eBay for £400 - Navitex. He repairs circuit boards rather than buying new boards etc. Took him 4 days to repair and send back.
If I wasn’t selling my car I would get the SSD upgrade.
![Clinking beer mugs :beers: 🍻](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f37b.png)
Hi, I was told motherboard not HDD. However, I will check the HDD hasn’t been taken out as paper strip will have been removed. It’s still boxed from repairer and won’t unbox till SaturdayThat's good to know.
Just as a follow up, can you confirm it was the motherboard and not the HDD?
![Thumbs up: light skin tone :thumbsup_tone1: 👍🏻](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f44d-1f3fb.png)
Looks like the HDD cover was opened and resealedThat's good to know.
looks like the HDD cover has been removed and revealed with his business seal. Not sure if it was replaced or just tested? I’ve asked him exactly what’s he’s replaced but no response.That's good to know.
