Firstly, hello to everyone as this is my first post. Some great stuff on here, so thanks for letting me on as a guest.
I have looked-up all the posts and trawled the internet for advice on how to trace a parasitic battery drain, have tried what I can but am now stumped. So, looking for your help to see what I can try next.
I have a 1989 2.7 Lux, I bought it 6 weeks ago and have been very pleased with it BUT it does have one or two electrical gremlins. This is really my fiddling and fettling car, I am fine on bodywork and some mechanicals but I'm no electrician! Whether I leave it locked or unlocked, the battery will drain in about 3 days. I have fully charged the battery (tested at 12.6v) and left it standing disconnected .... holds its charge no problem. The battery is only 9 months old so I have ruled that out as the cause.
I have done most of the obvious stuff like checking for glove box light being on in the dark, the connecter on the rear hatch strut etc. The interior and boot lights don't work, have changed the bulbs (still don't work) and set the switches to the middle position for "off". Used an ammeter setting on my multimeter and get a reading of 0.28 drain. Went through pulling all the fuses and relays in the engine bay but the reading stayed pretty constant. I would have thought that if the interior lights circuit was grounding that this would have disappeared when I pulled the fuse. I knew the intermittent wiper relay was duff and I have taken that out but I am still getting the constant reading on the drain.
Any ideas what I can try next? Thanks.
