Keggers
Hi All
Discovered something quite strange last night when walking back to my car. Turns out that if the indicator stalk is left on (i.e. to the left or right position so that the indicators flash when the ignition is turned on) when the ignition is turned off, the front parking light on the relevant side of the car turns on. Turn the ignition on and the parking light on that side goes off and indicator starts flashing instead (as you would expect it to). Note that this happens with the headlight switch turned completely off. The headlights and parking lights work fine with the headlight switch turned on in the relevant position, just that one of them also comes on when the indicator is on with the ignition off!
Am completely puzzled by this, but it may explain why the car is sometimes a bit slow in turning over given the obvious battery drain that will be going on.
Hope I have explained this properly without confusing everyone!
