Parrot Mi9100
markr
Has anyone tried fitting one of these bluetooth/ipod connectors to their car audio, it looks fairly straight forward and a lot cheaper than some of the alternatives. I have a CDR23 with the bose upgrade, but not sure if there is a seperate amp for the bose system. If there is a seperate amp then I'm not sure that I can fit this piece of kit. Any advice appreciated.
I think you might have a problem fitting this. Bose has a separate amplifier (under the plastic panel in the luggage compartment) and gets its audio input signal from the MOST (fibre optic) loop. There are no other audio inputs on the amp, or CDR23. It is very difficult to integrate into the MOST bus, and the only one I can think of is the Dension Gateway 500. Quite a few people here have had success with it.
