nags
I have a 944 turbo and it is having some boost production problems...
At times, it is not making full boost pressure (but always makes some). It will get quite happily to around 1.2bar (on the dial), but generally not any further. Other than that, it's running fine.
I can't really replicate the problem on call, however it does seem to be able to 'build up' boost all the way to 2 bar if I use partial throttle - but drops back off as the accelerator is pushed harder. The main suspect is the wastegate at the moment, but as it is generally able to hold boost using partial throttle, I'm beginning to wonder whether that is the wrong tree to bark up.
The boost solenoid has been ruled out, has anyone experienced anything similar?
