parts and part numbers.
homesea
Can someone confirm I am ordering the correct parts before I place an order?
First up I snapped the inside front anti roll bar holder last night (the inside one, not the drop link). The only place I can find them is from OPC. Part number 944 343 731 01 but different part numbers I think for different size roll bars, Mine is a standard Lux 1987. So I think the part number above is correct, can anyone confirm this.
Second I was going to fit 968 castor mount as I have 17" cups is the correct part number 951.341.023.01, it just confused me a bit as it started with 951. Do I also need the eccentric bolt part number 951 341 431 02 to fit them or can I just use the bolts I have?
Thanks.
ORIGINAL: homesea
944 343 731 01 [...] Mine is a standard Lux 1987. So I think the part number above is correct, can anyone confirm this.
Online PET says the same as you.
ORIGINAL: homesea
Eccentric bolts are the same, so 968 caster mounts will fit fine.
