parts from Glenn at OPC Leicester
Ewan
Having met Glenn at Rutland it seemed only polite I sourced my latest bits from him. So in case anyone wants to know prices, this is what I've just ordered and their prices (including Vat and delivery).
Pair of black plastic door kick strips £78.
Pair of black window scrappers (exterior) £48.
Pair of black rubber roof trim strips £29.
Pair of black rubber surrounds for rear quarter windows £54.
I can't believe I've put up with the old cracked rubber seals for so long, as they've annoyed me for ages.
They are the thin black strip that goes along the gutter. Have no idea about fitting - it won't be me doing the actual work! But there was a thread on here a few weeks back explaining how to do it.
Not hard just fiddly
Pull the old ones out first then you can see the clips for the trims, take note of the way they are fitted in the trims
I didn't even know about "clips". Oops. I'm sure it's just one of things the chap doing the fitting will sort out.
I just remembered that Glenn said I'd need 10 clips at 14p each, but I think they were for the kick strips. Not sure exactly what they're for, but bought them anyway.
I bought 5 clips just in case, there were 2 already broken so it worked out fine, think they were 86p each
Were they part no. p999.591.732.02 if so apparently pet says you need six per side but when I did mine there was actually either 7 or 8 fitting posts for them so I was going to suggest buying some more.
If they are the same part then I have been ripped off as I was charged 72p each.
Does anyone have Glenn's email address at Rutland?
I need to check on front indicators (Orange).
Ian
