PAS cooler line (update/more questions...)
amrbose14
First a bit of an update on the PAS cooler line. It is off, and I am getting a new one made by powersteering.co.uk, as suggested. The chap is very helpful, and usefully cheaper than the other source I'd found.
Right now I have three problems:
1. I cannot get the banjo bolt holding that end of the return pipe onto the steering rack loose. It is very difficult to get to - on top of the rack and under the engine. It takes an allen key - and appears to be quite shallow. Although I can get an allen key and may hands in there, just about, I do not have the purchase to loosen it. Already the hex shaped hole is beginning to round. Has anyone any tricks, or trick tools, to achieve this? I've instead removed the main wiggly pipe section of the return line form the ~4" of flexible hose joining the 2 metal sections. I can attach the new one at this point, but I am concerned about the (27 year) old flexible hose weeping afterwards, and I will be getting the new complete length from the rack to the reservoir.
2. I was going to replace the rubber pipe going from the reservoir to the PAS pump. Then I discovered it is attached to the engine by two inaccessible bolts, nestled behind the radiator fans. Has anybody removed this without removing loads of extra components? In which case how, and did you manage to reattach adequately? I can barely get my hands in and fear even if I got them off I would never be able to tighten up the new pipe.
3. What is the PAS oil reservoir made of? It almost seems to be porous. Is this a function of the age? After cleaning the outside with paraffin it is still quite oily.
Chris
Hi Chris
glad you contacted Richard he does nice quality work
I would not not undo the banjo bolt but change at the flexible pipe fixed under the chasis leg but I guess you have sorted this
now this maybe rubbish and I'm sure someone in the know will correct if I'm wrong[;)] but the hose from reservoir to the PAS pump changed on later cars due to a leaking issue the later one drops down by the oil filter it is a shorter hose i believe the fitting on the PAS pump has to changed but parts are cheap from OPC
My reservoir is a brown colour but I have just purchased a new OPC one and thats black and feels more like plastic
ORIGINAL: Kongsodoken
Seems like a nice guy.
I would not not undo the banjo bolt but change at the flexible pipe fixed under the chassis leg but I guess you have sorted this
OK - that is where I've disconnected it now. Initially I struggled to get it off at this point but once I'd bent the whole thing down a little it was easy enough to work it off.
Huh... that sounds a lot easier. Mine snakes off to the left, down the front of the plastic cam belt cover, and curls back around to meet the pump.
Yes, mine is brown and very light, but feels not quite like plastic. How much was the replacement?
Your hose sounds like the older design, I purchase the reservoir about a year ago so can not remember the cost but from memory the hose and the reservoir combined was around £50
