I took a trip up to Center Gravity in Warwickshire to let Chris Franklin take a look at the suspension and give me a definite answer as to what was causing the noise. For anyone not aware of Center Gravity , it is run by Chris and his wife Jane. Chris has many years of experience setting up complex suspension systems for track and road use on a wide variety of cars, though he has now focussed his work on Porsches. As a true enthusiast for the marque , Chris understands the particular requirements of each customer before setting up the geometry to suit. In my case he was able to dismantle the complete rear suspension and send the shock absorbers away for same day (non destructive ) testing , at none other than Bilstein themselves. Whilst the car was in pieces each suspension component was carefully inspected and tested before being refitted to the car. The results from the Bilstein tests showed both PASM shocks had failed , though all other parts of the suspension were found to be sound. I'm not aware of ANY independant or Porsche service center able to offer a drive in full diagnostic for Porsche suspension problems , so it was well worth the visit. Most garages and even OPC centers tend to guess what component has failed and work their way through the potential causes replacing parts as they go. This is not only very costly but completely frustrating for the customer , as repeated visits are required before the problem is eventually fixed.
