Quick update :
Car went into Center Gravity today and the rear shocks were removed and sent for testing at Bilstein. This is by no means a simple task as I was soon to find out. Basically the whole rear suspension , disk / caliper and hub assembly needs to be removed, then the damper dis assembled. Thankfully Chris Franklin is very experienced in doing this sort of work and made the whole process look routine. After the strut had been removed it was a process of dismantling to get back to just the damper , before Chris's wife drove them up to Bilstein for testing. I was very impressed with the quick turnaround at Bilstein and Center Gravity , due mainly to the excellent relationship that Center Gravity have with them , the Bilstein sfaff even staying late on a Friday afternoon to do the tests !!!.
The testing equipment at Bilstein seems second to none , each damper tested over a full range of loads and a bump and rebound plot produced as a result. The test results did in fact prove the rear dampers/ shocks were faulty as one had a particularly bad response whilst the other showed an almost inverse plot to what was the norm. Strangely enough one damper felt warm to the touch compared to the other when removed from the car , as it turned out the cooler of the two dampers was in fact in worse condition !
Whilst the dampers were being tested Chris took the time to talk through and demonstrate simple tests to prove the other suspension components were in good order. Having satisfied himself and myself that there were no issues with any of the bushings or ball joints the parts were cleaned and prepared ready for re assembly.
This may seem to some as an exhaustive and expensive length to go to , but having seen the damper plots I feel that it was time and money well spent especially as it gives more weight to my warranty claim to have the dampers replaced. I do not know of any Porsche specialist or Porsche center that has this facility to test dammpers , it also encouraging to see the time and care that Chris shows in resolving these sorts of issues for is clients.
For others with PASM equipped cars that may have been told by Porsche they dont go wrong , I think it also shows that PASM dampers can fail even on relatively low mileage cars , my car is just over 40k at the moment.
