Passenger aibag deactivation (987)
- Thread starter thboxster
If you're asking the question, you're presumably thinking of putting your/ someone's child in the seat - do you really want to take the risk for the sake of saving £400?
as far as i know it is only the porsche way that is possible, they have to fit isofix bracket to seat and a switch to dasboard side and a warning light to centre console...... unless someone else does a kit
Norway fitted it for £25 and he sold be a secondhand one for £50. Not bad since OPC wanted £250.
ORIGINAL: kenwoods
I had the airbag deactivation kit fitted to my 986, which Norway did. On the 986 all they fit is a seat buckle under the seat which is connected to the computer and then you just tell the computer that the airbag deactiviation kit is kitted. So then when you put a buckle into the connector a light flashes on the dahboard for about 30 seconds telling you that the airbag has been deactiviated.
the problem is that Porsche removed that idea on 987/997 and put the new one into practice for iso fix and safety reasons
leesweeney
It's a lot of labour, hence the cost. Just get a good independant to do it though.
