Stephenjk
Hi,
The passenger side speakers (tweeter and main speaker in door card) arent working. I’ve swapped one of the speakers from passenger to driver and the speaker itself works, hence I’m assuming the problem is wiring. I’m guessing the most likely failure point is going to be between the door and the wire into the cabin. What do you think and any ideas where to start? I’ve a becker grandprix. I did check wires into the stereo and they also look okay and rear and driver side speakers are fine. Just looking for some advice on if the typical failure is going to be the wire into the cabin from the door or not and how to go about replacing, do i need to start by taking the door card off? Or can i get to the wire some other way? Should i also check the amp? I‘m not sure if i have one or where to find it.
It has never worked in the time I’ve owned the car unfortunately so no clues there!
thanks
Stephen
thanks
Stephen
