Hi all, have issue with my passenger window, and would like some advise / ideas before I start guessing.
20001, 3.2s
When door open, the window no longer drops, then when the doors shut, window motor keeps clicking to shut the window, even though window is shut, opening and closing the window via the button makes no difference,
If I open the roof, unhooking main catch the windows both sides lower slightly, as usual , and the lowering and shutting of the roof ,the windows lower and raise as usual,
After a couple of minutes everything fine, then for no reason the whole thing starts again, it has also happened when getting in from the drivers side, and not touching passenger door, window switch,
Opening and closing the passenger door makes no difference
So a bit baffled , connections good, solenoid working, button working, power to window good, roof /window combo works,
Ideas please,
20001, 3.2s
Ideas please,
