Having had a squeak around the rear of the passenger window area for about a year I've done just about everything regarding cleaning the seals, checking their locations and such lubricating them with silicone grease or oil, even to the point of finding a dry film silicone lubricant but while it clears for a while it always returns.
So it has been for about 6 months of trying but at last I seem to have tracked it down to the weatherstrip on the outside of the passenger window, it's either that or something in the window mechanism. The felt of the strip is in good condition but whereas the driver's door weatherstrip is solid on the door the passenger side flexes significantly for about the rearmost 6 inches and so seems to be moving around on the location step.
I'm a little reluctant to try pulling the strip out as I can't see how it locates. I have sprayed some silicone oil and grease in and it stopped but once it dried out the squeak returned so I'm pretty sure I have identified the whereabouts of the fault.
Anyone know how to remove/refit the strip?[8|]
Currently considering getting a new strip as much to take a look as to actually use.
