Has anybody had issues with these units? I am experiencing two problems: 1) The PCM headunit will skip tracks if you hit a bump in the road, suggetsing the anti shock memory system isnt working on the vehicle? It will generally play fine 75% of the time. Also, the CDC-4 disc changer has various issues, such as not recognising all 6 discs in the changer, not changing discs to the next disc and skipping maybe 2 discs forward. These issues are all random and do not appear to have any pattern? I am going to try a new cartridge in the changer and see if that helps. Looking at Audio upgrades maybe!
PCM 2, CD HEAD UNIT & CHANGER ISSUES
- Thread starter M241115
kasspa
I have experienced similar probs with not recognizing all cd's & put it down to dampness in unit.
Some say this happens with 'copied' discs but I gave mine a good spray of compressed air that you can get in a spray tin, cleaned cd's & not had a repeat of problem in a couple of years
hth
hth
I would try a CD cleaning disk in the head unit first. If that doesn't work, it is possible to change the CD mechanism, but not for the faint-hearted:
http://www.renntech.org/forums/tutorials/article/248-pcm2-cd-mechanism-swap-due-to-ejecting-problems/
I tried a CD cleaning disk, but no joy. Might try another one just to be on the safe side. I can't open that link, but don't think I would be up to the task of changing it! I have ordered a new cartridge to try in the changer, so this might work. The CD changers are about £500 from Porsche, but about half that on ebay I think. thanks!
You may need to register on RennTech in order to see it.
If you don't fancy DIY, try Maple Audio, as they do a replacement drive service: http://www.mapleaudio.co.uk
No, it isn't. PCM users had to wait until 2006/7 before they could play MP3 CDs. Porsche are really on the ball with ICE technology - Not!
