I appreciate there are a million threads on the Interwebs about the PCM system and its myriad problems! However, I'm looking for some advice. My 981GTS battery went flat (totally flat!) after a couple of weeks non-use. I disconnected and recharged it, which took a couple of days while I worked out how to get the charging started (my CTEK charger won’t charge a battery that’s below 2V). On reconnection, my PCM3.1 emits no sound from any source, and won’t change source when selected on screen. I’ve rebooted, done a ‘handover reset’ and no change. The floor area is perfectly dry (the drains were checked by OPC Colchester who were the last to drive it before I let it discharge). Before I start bracing myself for changing components, any ideas?
PCM 3.1 problems - no volume, unable to select source
- Thread starter TimC340
Ok, problem found. The car has recently come back from a major service at an OPC, at which I specifically asked for the drains to be checked and cleared. The return trip was the last time it was driven. It looks like what they've done is ram a shufty-stick down the drains and blocked them! Of course, in my diagnostics I did a load of Googling and everything refers to the amps etc being on the passenger side, and of course they are if your car is LHD! On checking the RHS underseat area this morning, it's well and truly under water. That explains both the battery discharge and the PCM issues. Fortunately, the OPC boss is a mate and will hopefully get it sorted. In the meantime, the battery is again disconnected and a GBFO humidifier is doing its best to dry things out!
