PCM goes nuts
markiii
Posted: Sat Sep 10, 2011 8:53 pm    Post subject: PCM goes nuts
Amazingly good timing as driving several hundred miles on holiday today
PCM (2.1) starts acting up this morning with the volume reducing of it's own accord.
2 hours in and the PCM stops responding to any inputs, volume doesn't work, can't switch between functions e.t.c
Then. It starts randomly rebooting itself at approx 4 minute intervals
Stopped for coffee and when I started off again it let me turn it off
The it starts turning on and then immediately off again at 2 minute intervals
Put up with this until I arrived at my destination as no real option
Nowhere near an OPC
For now I've pulled. The fuse and hopefully tomorrow it will have fixed itself
In case not, any suggestions?
well just to follow this up I'm glad to say pulling the fuse for 24 hurs seems to have fixed it, and touch wood no reoccurence
having spent last weekend in wales it did the same again
the only common scenario I can think of is both times I've had the nose full of luggage
I'm thinkng ether something is overheating or a wire/connector is being pressed on something
more investigation needed but I'm leaning towards the heat issue as I packed a little less in on the way back and it still did it
You'd think, but it was fine Saturday empty of luggage but Friday on the run up and Sunday on the way back whilst fully loaded it was a pain
