PCM problem-Microphone unit
- Thread starter delboy
You'll find it in Group 9, Illustration 911-10, item 19.
Watty
Working in Spain at present, but will try fixing an external microphone when I get home now - Thanks for the tip Richard!
Ian
If not you could remove the cluster to see if the wire is trapped. The attached instructions are for a Boxster, but it is the same procedure, except that you have to unclip the hazard warning light switch trim.
