PCM
Barrowboy
Hi All,
I have a 2001 C4 with PCM.........the owners manual states it is possible to have the screen "North" up or "direction" up, I cannot get the system to accept direction. Has anyone else come across this problem?
Also is it possible to get updated disks?
Paul
It very much depends on which month yor car was built. Very early 2001 was First Generation PCM1 (8bit) and from Feb was Second Generation PCM1 (16bit). If you have a 16 bit system, try contacting Gerard Mahoney at SatNavShop on 0121 773 7000, as apparently he has 2008 maps for PCM. If it's 8 bit, there might possibly be an updated Porsche disk, but at £410 you could buy 4 TomToms and get change. [link=http://www.porscheclubgbforum.com/fb.asp?m=378926]http://www.porscheclubgbforum.com/fb.asp?m=378926[/link]
(date format is mm/dd/yyyy)
