I have been following a thread on the Renntech site in the USA regarding a claim from a guy in Germany that if you have PCM1 with a 16bit nav computer it will read Opal (Vauxhall) nav discs which unlike the Navtech discs for Porsche are upgraded after 2002. The nav will only read the Opal discs if the software used is v5.43 and to check if you have this software you hold in the A/C button on the PCM and at the same time press the selector knob to the right of it for 3 seconds and the information will be displayed.
Well I did all this and found I have v5.43 which indicates I have the 16 bit (as opposed to the earlier 8 bit nav - 16 bit was fitted after 2001 apparently) I hot footed it down to a Vauxhall showroom and asked if I could try a disc in my car. They obliged with a 2004 CD but alas it didn't work. The obvious benefits should this have worked is the Vauxhall nav CD is updated on a regular basis (there is a 2005 CD and the only thing that would be missing is the OPC locations, replaced with the Vauxhall ones!!!) and the cost of a 2005 CD is £125 +Vat.
In his post he mentions 8 discs as part of his CD package with his nav and this got me wondering and I have a couple of points I hope people can help me with
How many software CD's are normally supplied with PCM? My car only came with the CD needed to run the UK nav programme and I assumed that's all there was. The car was second hand and bought from a dealer (not Porsche)
A question I know has been asked before but I still don't have an understanding on - is it possible to buy an update for PCM1 from an OPC that is later than 2002?
If any of you want to check out the Renntech thread it can be found at http://www.renntech.org/forums/index.php?showtopic=4807&hl=
TIA
Ron Bonner.
TIA
Ron Bonner.
