PCM1 IPOD INTERFACE
slick0007
Hi i have done some digging and found this box of tricks to interface old and new ipods with a pcm1. The box iis called a solisto extra and is available on ebay (germany) for about a hundred quid. Does anybody have any experience of this system or is there somthing better out there any advice welcome thanks peter
ps Iwould have put a link in if i could sorry
i had one, worked OK, but make sure you get the right lead for your ipod i.e. hte new ipods require a different lead to the older sort.
system couldnt cope with more than 50 tracks per playlist, but that was more the becker head unit i was connecting it to rather than the solisto unit
well made and simple to fit
I fitted one about 6 months ago. Great bit of kit. The new ones are ok with new and old iPods. The only problem I found was if using iPhone with a Bluetooth phone kit. The interface and the Bluetooth can conflict and cause some odd problems.
A big improvement over the cd changer though
dave
"A big improvement over the cd changer though"
But still having to cope with the same old awful (by modern standards) PCM1 satnav unfortunately!!
Dave Jones
thanks for your input i have pondered removing the pcm1 and fitting somthing a bit more recent and media friendly but i like the original look i will ponder some more thanks peter
you could always change it for a new double din sat nav system like pioneer or kenwood - with everything included and bang upto date satnav?
its far less of a compramise, and the hard part is the change around to a double din, which you already have, so it would almost be plug and play to fit it ? plus put the old one up for sale which proabably give you a couple of hundred back towards what youd paid for the new one?
