Pcm3.1 (62 plate) - need aftermarket Bluetooth telephone
Shry1
Hello,
i have just purchased a 62 plate cayenne and only after purchase did I realise the PCM was without Bluetooth phone prep even though Bluetooth music from my phone is allowed.
Although its a £250 option when buying new Porsche have quoted £1250 dotted as they have to order a new upper console with a mic fitted rather than fitting it to current one. Plus 3 hours labour.
Its ludicrous considering it already has Bluetooth connection for music.
So so any ideas on what after market things I can do w are integrated ?
I have purchased the extended 2 year warranty and don't want to invalidate but need a solution for phone Bluetooth.
Thanks.
Does your car have the AUX socket installed under the lower center arm rest? If so you could use something like the i-clip which plugs into the AUX.it's not perfect but works well in my Cayenne.Or you can go for module like this
361360255427 or in my Carrera I installed
a kit from VISEEO.
Hi Angus,
thanks for the reply. Yes I have a usb and aux connection in the arm rest console.
The I-clip you mention is I presume an aux cable which you leave connected and it has a mic attached to it wired to the cable in aux and this has to be near the visor or somewhere where it can pick up the voice.
is it like the belkin hands free bluetooth set? It's a good idea but wanted a no wires showing solution u less I misunderstood your suggestion.
The second suggestion 361360255427. Was it for the
[FONT=verdana,geneva"]ISimple isfm2351?[FONT=verdana,geneva"][/h1][FONT=verdana,geneva"]that seems to use the fm frequency to tap into the in car system and is better solution and I will look at the pros and cons for this. [FONT=verdana,geneva"]
[FONT=verdana,geneva"]The viseeo seems only for he pcm 2.1 rather than 3.1. [FONT=verdana,geneva"]
[FONT=verdana,geneva"]I am waiting for sound specialist to come back to me about sourcing all the Porsche parts and fitting and see if I can get it done for half the price Porsche charge. [FONT=verdana,geneva"]
[FONT=verdana,geneva"]It it would be good to get it fully integrated and would help when I sell the car on. [FONT=verdana,geneva"]
[FONT=verdana,geneva"]Cheers for for the suggestions. [FONT=verdana,geneva"]
