Dave Wilkinson
Many of you will probably remember the continuing problems I have had with my C4 and the annoyingly consistent occurrence of the PDAS/ABS alarm when driven any distance. Over the summer the problem seemed to get worse (i.e. you could driver shorter and shorter distances before the dreaded alarm struck. I discovered that the problem was definitely temperature-related but that didn't help diagnose it.
In desperation I recently booked the car in to JZ Machtech to let Steve have a go at it. Interestingly, Steve insisted on looking at the ignition system before attempting to look for more complicated issues "" he said that many cars had displayed similar problems that were caused through HT tracking. Low and behold, he discovered that both the coils were showing very bad tracking damage, as were both the distributor caps and rotors. I'll post some pictures of the old parts on my web site later in the week if anyone is interested.
Having replaced both coils, distributor caps and rotors as well as a couple of "less than perfect" cable ends (sum total almost £400) is seems like the car is behaving at long last. I managed the drive home from JZM without once seeing the age old problem!!! I'd still like to get a few more trips under the belt before getting too enthusiastic "" but it's looking good.
Dave
