PDLS fault.
- Thread starter adrianb
Yes tried a few times, system won’t let you switch on the move which was ok on M27 but that was shut for roadworks & M3 was also showing closed, so decided to go A road via Alton at which point could not see past the bonnet
![Exclamation mark :exclamation: ❗](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/2757.png)
![Face screaming in fear :scream: 😱](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f631.png)
![Thumbs up :thumbsup: 👍](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f44d.png)
I know exactly what you mean about the road closures, I had the very same experience upon my return from France 5th July but without the PDLS problem. VERY annoying especially when tired and looking forward to a smooth journey home to Basingstoke after covering some 3,000+ miles around Portugal, Spain and France without too much trouble!adrianb said:Hi Robin,
Yes tried a few times, system won’t let you switch on the move which was ok on M27 but that was shut for roadworks & M3 was also showing closed, so decided to go A road via Alton at which point could not see past the bonnet️Then A road closed so ended up going to Winchester to get back on M3, welcome back to UK, roads are a nightmare
1500 miles in France no problem
What is the difference between PDLS and PDLS Plus? Porsche Dynamic Light System Plus has two added functions. First, at speeds higher than about 40 mph, the dynamic main beam will turn on and detect oncoming traffic and vehicles in front of you. The light cone’s intensity and range are adjusted depending on the surroundings. Secondly, Intersection Assistant turns on the electronic cornering lights to adjust the broadness and length of the light cones, which increases the visibility of the vehicle’s surroundings.
