Peak Power
- Thread starter Guest
There should be graphs in the back of your owners manual.
I can't remember off hand where the peak is for the current model, but on my 2001 "S" it is at 6200RPM I believe (with the standard Boxster having peak power 100RPM higher at 6300).
Your car is newer, with a revised engine (Variocam 2) so it will be different, but probably still pretty high up the range.
It can't be run in yet though? It seems to vary, but I was told to run in for the first 1000KM (not exceeding 5000RPM). The recommendation for your car will be somewhere near the front of your manual.
I hope this helps?
Black80XSA
the engine will still be tight, and you've 600 miles more runnign in to do. after that start to stretch the revs occassionally, building up to 7k revs over a few weeks.
The 2.7 is pretty torquey once run in, but only really starts to pull at 3k revs and is in its stride at 5.5k when the variocam kicks in.
