performance air filters suitable for a 944s
- Thread starter j4mou
TK2015
Wigeon Incognito
The reason I ask is that I have read some recent discussion elsewhere about such oil covered filters being a poor choice for cars with an AFM such as ours as the oil can slowly migrate into the AFM gunking it up.
Any opinions?
appletonn
For me, the main benefit to these reusable type filters is the fact that you don't need to buy a new one ever again.....
The airflow improvements, and thus power gains, over the standard Porsche filter is minimal.
Any gain in power over the standard one, would be more than outweighed by the loss in power caused by the engine inhaling warm air from the engine bay, rather than the cool stuff from under the spoiler.
I like the idea of an intake kit for mine, but would need something that sucked nice cool air from beneath the bumper area. There are some kits that simply remove the turbo airbox and clamp a cone type 'performance' filter to the throttle body, but that is then just between the radiator and the turbo which cannot be good for cool air!
I am unsure of the turbo's air filter location but I think it is in the engine bay rather than under the front slam panel like the S2. The advantage of the airfilter box /intake being under the slam panel is that it takes far more cool air as it is fore of the engine bay heat. It does however pick up some reflected heat bouncing of the radiator but that is minimal compared to engine bay heat.
Is it possible to fabricate a filter system for the turbo to sit in the same location as the S2 or will it have other implications on flow and engine dynamics?
I am looking at other filtration for my S2, a K&N panel is the obvious easy way to go, but I welcome others experience with cone type filters.[/i]
xenon
ORIGINAL: PJS917
I am looking at other filtration for my S2, a K&N panel is the obvious easy way to go...
And probably the best too. As well as the cooler position of the filter on the S2, the airbox is also designed as a resonant chamber and is supposed to help flow. I'm not convinced with cone types.
That said, the airbox cannot be resonant across the entire rev-range so it might be rubbish, but I read it in the Peter Morgan book or the Porsche manual or somewhere.
The S2 air intake under the badge panel struck me as quite a clever bit of design - using what was previously an un-used bit of space (although I understand that on the turbos there is an intercooler in there, which may prevent the mounting of a turbo air intake there.)
The S2 air box can be modified - see photos here:
... four big holes in the front of it (with a paper filter behind.) This method has worked well with Golfs I have owned, and is known to work well with 968's, but the result on my S2 wasn't fantastic. It did feel more powerful, but not much, and changed the mid-range throttle response for the worse (slightly). I did it soon after buying the car and thus can't honestly remember what it was like before the work, but I do recall being almost slightly disappointed by it.
On the plus side, it did produce a good 219.6bhp at the last Weltmeister day, so something is going well in there. The engine is otherwise stock.
Peter - I'd be interested to hear what else you have done to get more oomph out of yours. I too am considering a K&N filter, but have yet to persuade any american friends to buy one for me and send it over! (They are less than £25 out there ... )
As for other mods I will be doing, to early to say yet, but I have improved my 968 with head work and decent mapping, the S2 is used for Hill Climbs/Sprints and trackdays and will probably end up being seriously lightened, crank flywheel etc as well as headwork. Early days and budget not seen, let alone past by the management.[] [][]
I took the inspiration from this:
http://www.968engineering.com/pdfs/airboxmods.pdf
... which is pretty much an account of the same thing done on a 968 (you probably know this document.) Having said this, I don't know of anyone who has done something similar with an S2. (I also removed the small clip-in duct on the inside of the air box, which is visibly absent in the picture.)
Yes, I think it may have affected the mid-range torque slightly. The big difference was to the 'engine' note (intake noise) - it became flatter and much more dull. I do recall however that it pulled much harder for a given throttle movement - you needed to push the pedal a lot less in any given situation to get the same acceleration. I *think* it may have made it a smidge more economical as well.
Headwork appeals, but is very expensive and my S2 is a daily driver. Peter Empson had (I believe) good results from the headwork on his S2 engine (in a lux.)
I have yet to experiment with chips or with removing the middle silencer, both of which are meant to make a big difference.
All the best with your S2 and hillclimbing - it must make a pretty good hillclimb machine!
appletonn
ORIGINAL: PJS917
The turbo airbox sits off centre to the right of the centre line of the engine bay, directly in front of the bonnet slam panel, with a 'snorkel' pipe running off to the right down towards the front corner of the wing - from wher it should collect some nice cool air.
What i really need to do, is remove the exisiting air filter but leave the box in place and somehow fabricate a cone type arrangement to fit on the end of the snorkel...
Or something like that...[8|]
I need to get my A/C condensor swapped out tonight, so that I can get back driving the thing and check my boost levels properly.
Even on my drive-on ramps, there's still not much room to get underneath it[8|][]
