Performance parts suggestions
- Thread starter Paulk7364
pauljmcnulty
Short answer is, unfortunately, not a lot!
The S does tend to be down on power, so the first place to start is checking everything is working as it should. Have you dyno'd it to see how far off the original power it is?
Then, if you want the car to go faster you're better off with attention to suspension, geo, some lightening, and driver training. Slightly increasing engine power alone won't make a lot of difference if the rest of the car is needing a refresh.
Also, before any messing with it, have you looked at things like the head gasket, cooling system etc.? All are likely to be hanging on, but will let go if you add more pressure on them.
andy watson
Moderator
Track days are fun too, of course I have owned other faster more modern machinery but I just like her the way she is, lots of driver input, loads of pedal and revs low down - a typical 80's 16v sports car?
I suppose it all kind of depends what you want from an ageing toy.....let's face it most of the modern little round the town, nip down the shop cars can see us off these days.
andy watson
Moderator
George Elliott
GTX3076
best suggestion so far
500hp potential Paul, but a fairly significant undertaking. Probably more power than you had in mind too?
George
944t
924nutter
924nutter
924nutter
MRGT
I had an 'S' for 3 years or so and loved it. once I got used to the fact that it is a very 'peaky' engine and has to be driven as such to get the best out of it. I did fit the promax chip (about £100 iirc) which gave it slightly more pick up below 4000 rpm, and generally felt more responsive on the throttle, but thats about the best you can hope for.
If the engines in good condition, then keep it above 4500rpm and it sings [
jonnyporsche
Is it just me or is this a different thread [8|]When I wanted to go faster than my lightly modified 944t (it has a performance stainless exhaust) I bought a 996 turbo. £36k for 430 bhp (based on its tubi stainles 100 cell cats giving +10 bhp) compared to how much you would spend on getting 430 out of a 944 it's not a bad deal. Plus, I dont expect my 996t to let go any time soon, and no matter how fast you come up behind someone in the 944 nothing gets out of your way as much as it does when you are in the 911.
