petrol is low??!!
- Thread starter mominator
Black80XSA
Suggest you run it til the light again and then refill - it should sort itself out.
Tool Pants
non Club member but v. knowledgable
Was driving away this weekend, with half a tank of fuel when it cuts out on a dual carriageway doing 80!! Turns out i had no fuel, but the computer and the needle was showing I had half a tank.
So so pi**ed of!! Could have been nasty..
What responsibilty must the garage take??
jac in a box
At first it wouldn't register the £10 of fuel I'd put in, took around half an hour - guage crept up slowly.
Same again with £40 of fuel.
Time for the OPC doctor
Jackie x
I carried on driving with the needle gradually movint to the fully empty position at which point it suddenly started to read correctly!
After various variations of needle positions versus actual fuel on board I took it to my OPC who found that a wire from the fuel level sender was interferring with the float in the tank.
The wire was re-positioned and I have had no further fuel level problem.
