Whenever I get into my car there is a smell of petrol. This rapidly disappears when on the move unless the throttle is floored in 1st or 2nd gears when there is brief strong smell of fuel.
I have replaced the filler neck for the latest revision (06) and inspected the fuel tank and pipes in the luggage compartment (which interestingly has never smelt of fuel) for leaks (there were none).
I suspect that there is a leak from one of the fuel lines that runs from the tank to the fuel pump or from the fuel pump to the engine bay. Are they easy to replace at home and ,if not, is it going to be expensive to get a specialist to do it?
Could this be anything else I have not thought of?
