Hi
I'd be very grateful if anyone could help me with a problem that has stumped two mechanics.
I own a 2001 996 Carrera 4 Cabriolet. For about 12 months, there has been an occasional petrol smell in the car. At first, it mainly happened when I started the car in the mornings, as if the fumes had been building up somewhere overnight. It also often seemed to happen when I braked or accelerated sharply.
I took the car to my local garage who did the following:
Changed oil
Changed oil, air, fuel and pollen filters
Changed the plugs
This reduced the problem a bit, especially the smell on first starting the car in the morning, but did not deal with it fully.
I then took the car to a specialist Porsche servicer in St Albans, called Jaz Porsche. They ran a full check for leaks but could find none. They then did the following:
Changed fuel tank cap
Changed expansion rivet
Changed bleeder valve
Again this had some impact but didn't solve the problem.
Recently the problem seems to be get slightly worse as the petrol tank empties.
I haven't taken the car to a main dealer as I've always found my local dealer to be pretty useless in fixing faults in the past.
Garry
Changed oil
Changed the plugs
Garry
