Petrol...?
- Thread starter London987
BP if we can't find Shell (although the car does not seem torun as smooth).
Shell V-Power or Aral Ultimate when abroad.
However the car will run on any old 95 if you have to [
Black80XSA
ORIGINAL: DavidB
OPC Reading advised me to ignore the label inside the fuel flap (which says super unleaded only)! Any views on this? I use BP Ultimate as the nearest Shell is miles away.
David
PS I am a member dispite the caption!!
You can use normal unleaded - each cylinder has knock control to cope with the lower octane rating. however you will not develop full power on this, debatable how much less. On the odd occassion i used normal versus super in other cars i got less mpg and worse throttle response
BTW Aral Ultimate = BP Ultimate (we are the same company now - which is the clue as to why I have no view on the Shell stuff).
