Petrol
- Thread starter Motorhead
I’ve a 718 2.5 GTS. Always use super unleaded when filling up.
With the current fuel shortages there only appears to be E10 available at the 2 local garages.
Is it an issue using e10 rather than super unleaded - it should be fine from a fuel system perspective, but I was wondering from a running perspective. In my previous base 718 I had filled up on 95 unleaded when super wasn’t available on a couple of occasions and had no issues.
No issues at all, same mpg, same start, same response, BUT I don't rag it on the public road (or anywhere else).
Overtakes well, doubt I'll ever go back to 99 in the car.
You can always put 99 into the part empty tank of 95, it just dilutes the 99, so 1/2 tank of 95 filled with 1/2 tank of 99 = a full tank of 97, simple as that, as advised on here a year ago.
AndrewCS
Your engine is designed to provide optimum performance and fuel economy using unleaded premium fuel with an octane rating of 98 RON Porsche also recognizes that these fuels may not always be available. Be assured that your vehicle will operate properly on unleaded premium fuels with octane numbers of at least 95 RON Do not use any fuels containing more than 15 percent ethanol by volume
RB
Brian_Innes
You'll also get better mpg with 99RON if that matters to you.
Brian
Synergy Supreme+ 99 ethanol free fuel[/h2]is very powerfull in the Z4 packs a big punch and works a treat in the GT3 and SPyder. best fuel on the market now.[/h2]
Brian_Innes
Mr Demon is correct in saying super unleaded optimises turbo cars to greater extent than normally aspirated engines.
I wouldn't use 95 Ron E10 unless absolutely the last resort.
We drive the best cars, they surely deserve the best fuel.
Brian
AndrewCS
I had to use the E10, two part fills of Shell ... the first on top of V Power, the second on top of the first E10, some 60 litres in total
On the full tank of E10 the car performed superbly, I am sure that no one would have been able to tell the difference ... the car was well used over some two hundred miles that day
As for optimum performance / the best fuel ... I am more than happy to trust Porsche`s guidance from their own Forum i.e. the vehicle handbook, given that I am less than an optimum driver [
AndrewCS
Of the majors only Total and Exxon-Mobil (Esso) refine in the UK, apart from Murco the other refineries are non mainstream names albeit with links to some of the majors. Many of the smaller Tesco outlets are at Esso stations, perhaps Momentum is actually Esso Supreme [
Fuel quality is also affected by storage, transportation and the seasons (vapour pressure management between Summer and Winter)
Remember the hiatus back in the day when vehicles were damaged by bad petrol, t`was cheaply imported from Europe in a tanker that had not had it`s tanks cleaned prior to loading
Our reaction to / opinion of fuel performance is therefore dependant on factors apart from RON and E numbers [8|]
I have had to put 95 ron in about 4 times over 45k miles, every time the car feels dead like it's in eco mode. THE ECU is quick to drop the performance but takes 3 tanks to get it back up there.
I only used V power 98/99 as long as I can remember and plan Euro trip breaks via Shell garages.
95 is shocking poor fuel I find , Tesco is poor also less trick cleaning in it, hence it's cheaper. As for air cooler cars avoid E10 !!! Shell was king, but has missed a trick, Esso has found a market in quality fuel and if you want what Porsche states BHP wise you need to buy the good stuff.
AndrewCS
Had been running for some two hours prior to the stop and as is usual, upon restart the car ran slightly quieter / smoother, less `rattle`. Whilst the engine noise / feel always improves with run time I put this change down to two speculative notions:
- Restarting somehow `resets` the engine harmonics ?
- The increased vapour pressure of the fresh fuel gives smoother combustion - running ?
All a bit butt dyno - placebo but hey ... the the world is flat elsewhere on the Forum [
