phone problem...
- Thread starter Mark H
unclewinks
Tanya and I sometimes have the same problem in our c4s ,either take sim out and clean or switch the phone
off,through the settings, this takes a couple of minutes to shut down,but like any mobile,you should switch them off for a couple minutes
every so often to re-boot,something to try,if not speak to tim at opc exeter very helpfull
Paul
unclewinks
Massive coincidence,our phone packed up the after,message you get checking car,no sim if so
get a new sim,we have ,works perfect
paul tanya
c4s cab x51
Mark H
ORIGINAL: SKITTLES
Hi Mark
Could you please try With and Without the Sim card fitted. Do you get the same error message? If so it looks as if the Phone unit is not reading /seeing the Sim card. Thats what i get with mine
No it says insert Sim card when none in... the turning off didnt help either.. another sim doesnt work either....bugger
Mark H
anthonyvickery
Not sure where you have got with this, but I have a similar problem.
When I start the car, the raido or CD comes on as normal, but about a minute later the music cuts out because the phone (SIM card) is 'initalising'. This can happen up to three times before it settles down. The phone works, it just spends a lot of time finding the net every time the car is used and the cutting out is annoying.
