Phosphate free anti-freeze
ashonen
hi
Im going to replace my coolant at the weekend so was wondering if you have to use Phosphate free anti-freeze if so is it easily available, or is any anti-freeze ok to use - what make do you use?
sy
Almost any modern anti freeze sould be phosphate free, it was only uncommon when aluminium engines were something of a rarity, which isn't the case now. Just check the small print, if its safe for aluminium then it'll be fine.
Hi there,I use prestone extended life antifreeze,this is phosphate free and compatible with all other antifreezes. If you google the name you will find their website and get all the info,hope this helps John
You could also go to a porsche specialist and have genuine porsche labeled antifreeze but make sure they only use imported german water,all the best John.
ORIGINAL: pegasus
I work for a German company so that should not be a problem to get[:D]
Doesn't work like that, the air would be tainted by poorly made british air you released into the atmosphere. Best to let them down, drive to the next town and then pump them up (best to drive into West Germany for this).
Make sure you do not combine blue/green antifreeze with red/purple antifreeze. This is not necessarily too great for the engine.
Thinking about taking mine to Japan to stick some of that 105 RON go-go juice they have over there [:)]
While you're there, bring me a jerry can of it too, please.
Maybe easier to import a bottle of Oxygen Free Air from West Germany?
Mike
I found this.............
Types of Anti-Freeze There are three primary types of anti-freeze for your car's radiator cooling system:
1.Ethylene Glycol/Polyethylene Glycol. Tried and true, this type of anti-freeze is still standard after almost 70 years. Modern ethylene glycol anti-freezes have several additives to protect, clean, and lubricate your cooling system.
2.Non-Toxic Radiator Coolant. This anti-freeze does not contain ethylene glycol or polyethylene glycol (both acutely toxic). These engine coolants are, however, still toxic but only in larger quantities and over longer periods.
3.Extended-Life Anti-Freeze. In most cases, this is simply an ethylene glycol anti-freeze with one or more carboxylate additives to prevent corrosion of the cooling system. These engine coolants should make your car radiator and cooling system last longer.
Common engine coolant additives include: nitrates (corrosion inhibitors, buffers), silicates (corrosion inhibitors, especially for aluminum radiators), carboxylates (buffers, corrosion inhibitors), and borates (buffers).
Never mix different types of engine coolant. You can damage or further reduce your car radiator's efficiency by mixing the different types. Before you change types, thoroughly drain and flush your cooling system.
The different types - made even more complicated:
OAT coolant (orange or pink) contains no silicates and no phosphates. It's a blend of two or more organic acids, a specific class of inhibitors with slow-acting, long-life properties. Texaco's Havoline Dex-Cool (also sold under the Goodwrench label by GM) was the first example. Prestone and Peak also have introduced OAT coolants that are chemically compatible with Dex-Cool.
Conventional Japanese coolant (green or red) contains no silicates, but has a heavy dose of phosphates and other inhibitors, including a modest amount of one or two organic acids.
Conventional European coolant (blue or yellow) contains a low dose of silicates and no phosphates, but does include other inhibitors, including one organic acid.
Hybrid European coolant (blue or green) is similar to conventional European, but with a much greater dose of organic acids. It's a balanced formula designed to have the silicates provide the primary protection for the aluminum, then allow the organic acids to provide long-term protection.
Great information Paul, the standard blue is the one i have bought so it looks like it will do the job without a problem[:)]
