golfprorich
Thoroughly chuffed with it, once I've given it a machine polish I will post a pic or two.
I am changing all 4 shocks on Monday as the front end is so wallowy but that was the main tool in my bargaining.
I expected to have to do a few little jobs so if anyone can advise on them that would be much appreciated.
First one is that when I pull the indicator stalk back to flash the beams, nothing happens. However when the dips are on I can flash the beams no problem. Any suggestions?
The other is no noise from the washer pump. It was too dark when I got home to starting fiddling with a multimeter but I will obviously checked for power first. If not maybe the earth?
Finally, the heating will either be cold or hot, there's no in between. If I twist the dial to minimum the air temp cools right down. When I move it just off minimum the air temp goes to full heat. With every movement of the dial I can hear a little motor whirring in the dash.
Any help much appreciated and despite the niggles I'm looking forward to owning a 944 again, the last time was 14 years ago!
