Picking up 2000 boxster s on saturday - fuel !
- Thread starter Guest
The compression ratio is certainly a factor - the shorter spark of 95 is more likely to cause damage to the pistons/valves with a high compression ratio than 98. To prevent this the car has knock sensors which back the timing off to allow the lower grade fuels to be used, albeit at the expense of power and efficiency.
You can use 95 - Try finding 98 in Italy for example... but it is designed for 98 and the car compromises to allow lower grades to be used.
So I am bound to stop when I see Shell stations.
I notice a 10% more efficient when using V-Power, compared to when I have
had to fill up with 97RON. Then it was only 5% more expensive as well.
I guess they are only guideline numbers anyway.
Dr. Skids
CountBrass
I found the comment at the end quite interesting: "Also, a few vehicles, such as the new BMW K1200R motorbike, can sense knock and adjust their engine tuning to take advantage of higher grade fuels. Another user commented that the 2004 BMW 330 also does this, according to the driver's handbook it makes 231 BHP on 98 octane and 221 BHP on 95. This ability is apparently widespread amongst German performance cars using Bosch / Siemens electronic engine controls."
I assume Boxsters fall into the category of "German performance cars"? (No idea if they use Bosch/Siemens electronic engine controls though).
Porker993
My only slight problem is, according to the very useful info posted above, no-one in the UK sells 98 RON fuel anymore. Sorry for shouting.
There's plenty of 97 (Esso and BP) and 99 RON (Shell and Tescos) out there, but no 98.
Now - I'm guessing 99 RON is not a problem for our cars, but surely 97 is not up to snuff ? I would be interested to hear views ?
