Play in driveshaft?
- Thread starter cococola
Many things can cause similar noises, and I have wasted more hours than I want to remember chasing what I thought were duff CV joints, which turned out to be loose brake pads. (Yes, it's not good. What's worse is that I have done it twice - D'oh!)
Any more symptoms with which to diagnose this malaise?
P.S. One or more of those may not be a serious suggestion. "Doink" doesn't sound like a CV-ish noise, but I could be wrong.
Scorpio.72
When I take a right hand full lock turn I have an intermittent knock(not loud).
Checked its not your knees? lol
You are quite right, but the outer joint(s) will rotate more quickly than the inner ones, therefore you can diagnose it like this. But you need to be a bit more attentive than with a FWD car.
(Note - "Outer" in this sense refers to the two joints on the axle associated with the wheel on the 'outside' of the turn, so the right-hand wheel on full left-hand lock, and vice-versa. NOT the usual designation of outside=those nearer the wheel.)
ETA: Completely agree in that this doesn't sound like a CV issue.
