edh
I've been checking this over this morning - I think I have a rear wheel bearing that is starting to grumble a bit, & one of the os inner CV boot ties is not tight enough, so has been leaking a bit of grease.
We noticed a bit of vibration under load on the last trackday, particularly at 120mph+. So is it the wheel bearing or the CV's?
But there is a fair bit of play in the n/s inner CV - certainly more than on the o/s. I guess that needs changing. And if the o/s boot needs doing (and the joint cleaning & re-greasing), I should probably do that as well...
- and then if I'm doing one or two CV's, do I do them all? presumably the Q-Drive CV's and driveshafts (complete one for £99) are a waste of time?
