Hi
I have a Boxster S 981.
I use the engine automatic stop-start feature (this is the feature that cuts out the engine when the car is at a stop to preserve fuel consumption, then resumes it as soon as you put your foot on the accelerator pedal).
On a few occasions, the engine has automatically gone off because I have been at a stop and when I have pressed the accelerator pedal it has not restarted. On such occasions, the dashboard has shown a message along the lines of "Please restart engine manually". The only way to restart the engine is to turn the ignition off with the key and restart everything (which normally includes turning off the electronic handbrake, too). When this happens on a busy road at traffic lights - which is invariably where it has happened - it can be very inconvenient as it takes a good few seconds to get the car up and running after initial flustering (and hooting from the cars behind).
Anyone else had this problem? Any suggestions to fix?
I guess one probable solution is to turn off the automatic stop-start feature, but I quite like that.
Elliot
Elliot
