Ian B Walker
I am in the process of putting a fresh engine into my shed, err car [
] I have been using all sorts of electronic reference manuals to assist me. In one it says that to fit the exhaust manifolds you need to remove the studs, true. What it does not tell you is that your steering shaft needs to be removed too. Or at least disconnected from the steering box. I toyed with the prospect of dissconecting the shaft, not that I really wanted to as it took me hours to fit it in the first place. I could have removed the engine mounts and slid the engine over two inches, but once again this is something I wanted to avoid. Hindsight is a wonderful thing. The best way by far is to fit it while the engine is out. Something else I learnt. The power cable to the altenator should be routed above the engine mounting. This will keep it out of the wet. I have changed the torsion bar bushes. Because I need them then and my nearest dealer is 2 hours away, I used ones from a Volkswagen. I will add to this list as I go on. No doubt I will have the more knowledgable members telling me that I have it all wrong and I will bow to their superior knowledge. I am just a newbie with 944's
