porsche 944 non turbo 2.5
p944
Can anyone help with ideas?
My Car starts idles for a few seconds and then cuts out.
the only way i can get the car to start and idle is by introducing a 12v at the coolant temperature sensor, this will start and let the car idle but will not rev above 2500rpm, if you don't introduce a 12v at the sensor the car will not start at all.
Fuel pressure regulator, fuel pump, distributor cap, leads, crank sensors coolant sensor have all been replaced,
i had loads of running problems but when i changed the above it run beautifully, then i parked it up one day and now wont go. :(
any ideas would be welcomed
