Porsche Boxster 2.7 2006
josef boni
Has anybody had problems with water coming into the car through both driver and passenger doors on the above model and how it can be solved?
Josef
If the trim at the bottom of the doors is wet then chances are the plastic membrane in the door has either come adrift or split - a common issue on the previous 986 series cars. Its a case of removing the interior door card, then either reglueing/sealing the existing membrane or buying new membrane from OPC - for 986 cars they were under £20 each.
I dare say somewhere on the internet has info on removing the door cards, there will be a host of hidden screws behind bagdes, door handles etc
2006 means 987 - which didn't have a membrane but a sold plastic "firewall" (or waterwall) - this had a number of plugs/fasteners which if you've had any work on the doors (speaker install, lock changes etc) then the technicians frequently "forget" to replace - which lets the water through.
You could strip the door and see if there are any obvious missing fittings....possibly only a few quid in parts - an hour of labour with a good technician or an afternoons DIY.
