Can anyone help?
my park assist has failed I think due to waterlogged carpet behind the passenger seat.
I have managed to dry everything out but the ‘Park Assist Failed’ appears on the PCM display.
I have searched the manual for the appropriate fuse but there doesn’t appear to be one.
I have poked a piece of wire and applied air pressure down the drain hole on that side and hopefully cleared the blockage.
Has anyone had the same problem and if so how did you fix it.
For the moment I have switched the Park Assist off on the PCM but would like to fix the issue if I can.
I can see a box under the carpet behind the seat which I guess got wet, but I can’t get at it.
I guess the seat will have to come out if I need to gain access.
I would have thought there would be a fuse that needs to be checked first though.
John
John
