Porsche Boxster 987
- Thread starter legin
Welcome to PCGB as already said you're cars a Gen 1 the Gen 2 came out in 2010 with the Dfi engine.
Enjoy you car.
Windyridge
Mine has a 111 warranty from Porsche till August 2022 , so this will help me worrying about engine issues
thanks again
paul
Windyridge
Paul
Im In Oxfordshire
My 987.2 is a 2.9 registered in Oct 2009 so I presume it is a MY 2010.
It certainly is a Gen2 car and the 2.9 I think is not a direct injection engine, that is for the 3.4 version.
So, when saying the Gen2 version is from 2010 is it meant MY2010 rather than registered date?
Paul's one is still a Gen 1 in 2008.
The 987 brochure that I found a copy of online said it was just the S that had the DFI engine - presumably the brochure is right and there was some further update to the non-S variant?
So does that mean the 2.9 doesn't have the DFI? Does that matter from a reliability point of view (i.e. is it something inherent in DFI that makes them less prone to issues?) I always thought it was down to the liner materials and the way the coolant flowed round the cylinders? By the way, I don't want to start the whole reliability debate - I appreciate that reliability issues are rare!
Am I also right in thinking VED is significantly lower on the Gen 2 cars - both of them? Relatively minor detail I know but it all adds up - especially for a likely fairly low mileage car.
Many thanks,
Gareth
The Gen2 2.9L engine shares the same (no IMS) core construction as it’s 3.4L counterpart but doesn’t have DFI. For the Gen2 engines the Lockasil block was abandoned in favour of a more durable Alusil process and improvements were made to cooling and to the oil supply and scavenge system, the latter using four rather than two scavenge pumps and an on-demand pressure pump. As far as I’m aware no major in-service reliability issues have been reported with either engine.
Although I’m unable to confirm it, I suspect that VED either will be the same or slightly lower for the Gen2 cars but perhaps further research online will give you an answer?
Jeff
