porsche boxster
- Thread starter hussain
Lift rear boot lid and remove oil and water caps
remove the plastic plate below the two caps - (false floor)
Put oil cap back on but not water cap
You will see a lever that needs to be pulled over and opens the vent -
Start the engine and allow it to get to opperating temperature.
As the thermostat opens the water will push the air buble through to the vent, the water in the expansion tank will bubble as the air comes out and the water level will drop
Top up the water, turn off after 5 minutes of opperating temperature and put everything back together - everything should be working now
