chaz1
Before we talk about cost we need to talk about the car
The best mid engine roadster according to most car magazines.
No doubt when you drive one you will understand the following these cars have.
So you need to balance the cost with the enjoyment the car delivers.
So to cost of this car these may not be total typical but most 987 this age will need a lot of these parts.
Car 2007 3.4S registered 2007 just two owners.
I met the previous owner and can verify the car was never mistreated and had no over revs recorded in the ECU.
Car purchased 2016 mileage 47,000 full Porsche service history.
Previous Owner spend at Porsche not including services
2012
21/11NSF control arm failure 217.00
2013
05/01 clutch failure 1222.54
2014
13/08 Exhaust bolts failures plus new O2 sensor. 832.00
??/?? Battery Bosch approx. 150.00
2nd owner
This is for parts only as they were owner fitted.
2016
24/09 Front brakes pads/discs and hardware. 330.00
29/10 Rear tyres Bridgestone Porsche approved. 275.00
30/10 Rear discs pads wear sensors damper shims. 230.00
2017
06/01 TPMS sensors x4 fitting balance activation. 440.00
06/01 Coil packs x6. 231.00
18/05 coolant pipes and coolant due to failure 240.00
18/05 front tie bars rusted. 80.00
18/05 4 wheel alignment after above. 50.00
18/05 N/S wishbone and cam bolt failure corrosion 376.00
23/07 Air con pipe failure re gas and dryer etC. 350.00
01/09 under tray due to stud failure 329.00
01/09 front arch rust repaint. 300.00
01/09 front passenger wishbone ball joint failure 276.00
01/09 clips for front bumper broken due to corrosion 12.00
17/09 Porsche battery to comply with warranty 165.00
coming up
29/11 Rear wishbones rebushed. 300.00
29/11 any other suspension bushes ?...
29/11 rear coolant hoses Coolant 240.00
29/11 rear gearbox mount plus labour 1000.00
Common failures that can and do occur quite often
Gearbox selection issue to second gear after 50,000 pricey replacement of gearbox mount or even gearbox
Road spring failures not uncommon but cheapish to replace.
Bore scoring due to short cycle or incorrect warm up Oil change or incorrect oil On both 986/987/981.
My advice would be to get an inspection of bores prior to purchase of any flat 6 Porsche engine.
981 seems to suffer more for body shell rust than the older 987 quite why this should be is still unclear
Hoping to get to the end of this list and start enjoying the car.
2012
2013
2014
2nd owner
2016
2017
coming up
