After Advice
I have a 1988 Carrerra 3.2 , just had it over a year. The car has Standard Calipers on the rear, but has 4 POT Turbo Calipers on the front with drilled and vented floating Discs . According to the History with the car , they where added just before I bought the car.
The History shows a NEW Master Cylinder Fitted ( not sure which Master cylinder was fitted Standard Versus Turbo ) as receipt does not quote part number.
I.ve changed the fluid, I,ve changed all the hoses ( Braided type), and I,ve renewed all pads , and ALL Pistons free.
So whats the issue!!!
The Car just scraped through MOT on Brake efficiency on front brakes ( plus Brakes Sqeal really loud), Rear were fine. driving the Car the Brakes Lack Bite . Theres no signicant Pedal travel . quite a hard pedal in fact (( which suggest to me a Turbo Master Cylinder has been fitted). My thoughts at the moment is an imbalance in the braking , i.e should the rears Calipers have been changed to Turbo Brakes? i.e 4 pots as well , my thinking for this is the Turbo Master Cylinder Shifts more fluid.( for the 4 pots) , but with standard rear brakes don,t really need this extra fluid so is thus making the hard pedal hard before the fronts have time to BITE. Can I change rear Calipers to 964 type and keep same Discs? or do I change front Calipers Back to Standard and change Master Cylinder to standard. Further thoughts on the Brake Squeal do front turbo calipers require damping pad between Pad and Piston??? Any advice thoughts would be appreciated
