Porsche Club RMS Survey Letter Recieved
- Thread starter Guest
(Make yourself a coffee, and find a comfy chair first...)
http://www.porscheclubgbforum.com/tm.asp?m=76854
http://www.porscheclubgbforum.com/tm.asp?m=79810
http://www.porscheclubgbforum.com/tm.asp?m=74016
http://www.porscheclubgbforum.com/tm.asp?m=62548
http://www.porscheclubgbforum.com/tm.asp?m=70613
http://www.renntech.org/forums/index.php?showtopic=15&st=0%EF%BF%BDentry24
Read carefully, we'll be asking questions to test your knowledge after...[
MikeO
By the way, anyone know how you tell whether the clutch plate has got contaminated with oil (supposedly one of the main risks)?
The main issue is how it leaks and what it infers. The current seal they use in an RMS replacement has a rear internal spring behind it which closes up around the crank. I believe this is the 3rd seal type they have used. So this infers that for most RMS problems its notthing more than a bad seal or the seal is badly seated. On the other hand if the block is warped then the leak is typically comong from the outer part of the seal; if the crank is warped or has wobble then the leak typically comes from the inner part of the seal. In both these cases the only answer is a replacement engine or a rebuild and the long term effects could be that the engine self destructs. Also bear in mind that the seal only lieaks during cool down periods. When the engine warms up or is hot the seal and the metals contract. When you shut off the ignition and the engine cools down that is when the seal and engine metals constrict with the possibility of warping and/or oil finding its way past the seal.
MikeO
GreigM
ORIGINAL: MikeO
I was lead to believe that one of the early signs can be a "squeaking" noise from the clutch when it is engaged under high load (at speed, or in too low a gear etc).
Grip the steering wheel, engage gear and increase revs to about 6,500rpm. Now look out of the passenger window.
If a) the scenery is stationary.
or b) you can smell a nasty smell from the back somewhere.
it means your clutch plate is probably knackered.
In all reality most clutch bellhousings will have fine contaminants present if you take it apart to look. Unlikely that oil, unless a very serious leak, could get onto your clutch plate, although the environment inside the bellhousing when hot would not exactly be oil free!
