The same OPC that you mentioned (and I had been a longstanding customer) refused to issue an extension to the warranty as I had a hard-wired dashcam installed. If is had been attached to the cigarette lighter socket it would have passed. Their 6 year service was several hundred pounds more expensive than the OPC in East London.
I do not understand why a non-approved battery should invalidate the warranty. Do you? The main problem as I see it is that they can afford to turn away business as there are enough mugs who will pay for anything. Come the downturn in the economy there will be some squeals from some quarters!
Suggest you contact the dealer you bought your car from.
Good luck.
Good luck.
